1990 5.3 Jimmy
awesome thank you
I have the same fans but only have one coming on at 190 the other via toggle switch
but I like you set up
mind sharing more details
awesome thank you
I'm not sure your setup, but the 5.3 computer on mine controls what temp they turn on and off otherwise you'd need two temp sensors. Im running a 3 relay setup.
If you run those tires for a day in Moab, I'll make sure I'm there!
Blazer Bash should have a street tire run. 30" max height.
They do a small tire run on the rubicon every year too. I don't like the idea on the rubicon because I know my axles, steering and driveshafts would get hammered in the rocks but I could see a run at moab being fun.
Have you figured out a Plan B to be able to go wheel if you still do not have tires in the next couple of weeks?
