So I think i have the perches in the proper location, and the springs are plumb. I have a 42.5" width between the perch centre pins. The perches are 2.5 inches wide (1.25 to the centre pin hole.). I did 42.5 + 1.25 +1.25 = 45" ... Inside width of the axle tube is 56.5 from backing plate, to backing plate. I figured 56.5 - 45 = 11.5. Then divided that by two, which is 5.75. So i put the perches 5 3/4 inches in, from the backing plate. I double checked the measurements and they are within 1/8 " tolerance all over.. If thats too much..? I can get it bang on, once i have a second set of hands here.
I then moved on to trying to set my pinion angle. So from what I've read. you want to get the axle up to ride height.. Not exactly sure how to do that. Can i just jack it up enough to get a tire on? I then jacked it up a bit and put it up on the stands.. and used the jack to push up the yoke to start trying to figure out the pinion angle.. I have read a lot about this, and its all kinda just been confusing me. So i tried to figure it out with my hands, which is how i learn the best..
I read that you find the angle of the drive shaft, then find the angle from the differential yoke to drive shaft, and subtract the two, to give you the actual pinion angle...
If i did this right, i would have 16 degrees on the yoke, and the shaft is at 23 degrees, which would leave me with about a 7 degree pinion angle. Once the differential, and T-Case angles match. They cancel each other out, and it should spin with little vibration?
