Worked yesterday but Turns out today is our family day stat holiday... Even though i dont have a solid game plan for the outriggers just yet, i figured id work on the drivers side some, as i knew the whole rocker area was worse. Turns out i was right... There was so much bondo in this corner, and found more signs of previous panel repair. Metal supermarkets is closed today because of the holiday, and i have no scrap sheet metal laying around, so i need to buy some before i can continue. I think theres enough good steel to warrant not buying another rocker panel. I might go see how much one would cost at the parts store, since im still on the fence about ordering new front outriggers also... anyway this is where i got to today, not much further but anythings better than nothing.
On a good note the drivers side body bolt came out much easier and i got to see exactly where the outrigger box is cracked... still not sure how to replace besides cutting big holes in the floor..
Sorta mocked up a line on the passenger side but the drivers side will have to be cut a little bit higher up to the door line , so ill redo the mark to match most likely.
The girlfriend brought up a good point that i should try and find a garage to rent for a month or two, and just tackle the rest of the rust repair so its over with as its not very expensive just time consuming. So the plan is to get done as much as possible before hawaii and then when i get back, start looking for a garage to rent.
also found 27 bucks.... a french fry, and a machete lost in the depths of the seat crevasse. That paid for the new wire wheel i needed and lunch, so that was a win also.
( The bottom line was my proposed cut )
