Yeah sure! I'm looking for an OEM hand throttle. Nos or not. And the 81 5.7 diesel tailgate emblem. I need one.
= we waste your money
Everytime this truck shows up in my 'new posts' feed, I have to click it.
.... Jeez. Is it too late to back out??
Deal and a half right there. Title is already signed bub
I’ll up the bid , two burritos and a 1/2 can of Copenhagen .
)I drive it all the time. Its runs and drives so well as it is no reason to take it apart. Most likely around September or so is when I expect to be ready to swap. If I have my way it will be a remove replace swap. The more prepared I am now with forward thinking, the better my swap will go. Like the f700 brackets. There are parts available to make this thing bolt up like oem which is how I want it to appear.
I also found this turbo 90 so I can run my filter to where the battery is now. Came from a freightliner fl60.
People say cummins swaps are easy. Yeah they are but mine is over the top. Way unnecessary. It's not just a motor swap. It's a column and pedal swap, core support swap with intercooler, radiator and condenser crammed in, firewall work, fuel filler necks and new tanks, fuel lines, the seats have to come out to do insulation, 205 has to shift got to make the tach and gauges work, two new driveshafts, then put the dana 80 in and make the cables work off the pedal, still got to regear and build the 80. Jeez. Is it too late to back out??
Alright, alright... I was trying to stay civil in this deal but you 2 may force me to bring out the $5 foot long and an Icee. Just sayin...
(interpret that however you want)
