1991 Volcano K5 - Family Wheeler - Fully Independent Twin Turbo BBC
Plate under the body too?
That’s the hard part about the dealer add-on bars. People kept the roll bars but not the bottom plate.
Yes, I made reverse plates for under, and I used some more 1/8 steel to tie it into the cross brace under the bed. I think the cage would be way too weak without either welding the top plates to the floor (not ready for that) or adding the sandwich plates under.
For now I did the sandwich thing for the beginning of an 8.50 cert per NHRA spec, I temporarily treated it like a unibody car, 6x6 1/8" steel plates top and bottom with four 3/8" bolts. I am only building the rear half currently, not making A pillar bars and/or a front halo yet. When I build the new chassis I plan to tie the cage into that chassis, which is why I didn't just weld the plates to the floor I haven't decided if I will just go solid body bushings or try to add poly bushings to the cage tie ins. IMO the cage tie ins and body mounts need to match and I am not ready for that quite yet. The tubing is 1 5/8" x .083 wall 4130 chromemoly which is what I used in my Regal per NHRA spec. This is not going to fully adhere to any NHRA or SCORE rule book, this is going to be a compromise for useability and access. Plus its basically a 4WD dune buggy that I will also do short 300 ft sand and dirt drags, I'm not going to be going 120 MPH like a trophy truck or over 150 MPH like my Regal, nor am I a rock crawler that might fall considerably and land upside down on granite.
This was just a mockup before I rounded the corners a little and it will come apart for paint once the double roll bar is done.
Does anyone know if this green stuff is factory for 91? Its pretty light stick on foam over 1/2" thick, but I worry a little in the midwest it will trap moisture. It seems patched in there so I am guessing not?
Spray on 'second skin', or some other stereo related spray on. There's a few.
They don't off gas like bedliner, and can't get moisture behind it like stick on mats can.
I’ve seen those. The spraying would be the hard part but could be made to happen.
I feel like a sound deadener with a soft top is kind of pointless.
If I did anything it would be something lightweight and probably spray on, but not at this time.
I'll probably just pull that stuff out and leave it empty for now.
Does make me wonder about a layer of deadener on the inside against the interior trim?
Adding deadener to panels cuts down on the rattle and resonance and psychologically makes the whole vehicle feel tighter. Lining the floor can cut engine and road noise. If you drive on the freeway, the dominant noise is probably all of the other traffic and you're right that the soft top will just let all of that in. "Noise" is the unwanted signal, so BBC vrooms aren't part of that category.
