I did something I don't recommend after doing it. I used 4 tie down straps, the kind you just pull by hand and they have a cam release. I couldn't use ratchet straps because the ceiling is over 12 ft and those things run out of travel quick. So I ended up moving the stool around each corner while I picked up that corner and pulled the strap down tighter. I had to do this for each corner, and after each time round I would raise it a couple inches. Then repeat, again, and again, and again. Then the last few rounds I needed the ladder I had used to mount the 4x4s up there.
But after starting it, it didn't feel very safe, until I finally got the chains hooked up. But I couldn't let it back down reliably either. I will have to do something more secure to get it down when the time comes, because releasing one of those types of straps would not be smooth. Anyway, don't do what I did.
After I got the chains hooked up I ripped a 2x4 in half, and screwed a 2x2 on each end to keep it from spreading, with an extra piece on each end to prevent it from sliding off. Figured that should be safer.
