This thread is for the general discussion of the Item 1994 Jeep YJ - The YardJeep. Please add to the discussion here.
I have a couple dozen acres of heavily wooded yard that is very moist most of the time as the "low" areas the water table is maybe 8" below the surface. I have a year-round creek and a 1.5 acre pond. Anything too heavy gets stuck most of the time. My Bolens 2wd garden tractor with trencher tires is about the limit. My mud truck in my avatar gets around fine but it's WAY bigger than my trails.
The YJ has a 4" lift on it now. I don't want to go any taller, would actually prefer less. I mostly think I want to put 33s on it so I can keep it fairly narrow so I don't have to make my trails too much wider (right now they're 66" wide).
From the below I can get the 285x70r17 for $1550 and the 315x70r17 for $3k locally.
I don't really need the beadlock wheels, but they do look pretty sweet... he has the 33" tires on the beadlock wheels for like $2600.
Yukon Zip Locker for Model 35 with 30 spline axles, 3.54 & up
* Fits AMC Model 35 with 30 spline axles * 3.54 and up ratio only * Forged case and 8620 internals for added strength * Works with a variety of air delivery systems * Assembled in the USA The Yeastcoastgearsupply.com
now you could match the front
bds-suspension.com
Yeah, they make 1" Chinesium wheel adapters which is what I need at a minimum to move the wheel back out over the balljoints because the JK and JL wheels have so much offset.
