Finally got it out of the garage yesterday. I have a leaky brake line, and of course it's the one I ran through the truss.
4.88s and 31s are a good way to get whiplash driving it around on the idle air control valve. The 20 year old $20 muffler is kind of loud.
I ended up abandoning the ZJ drop pitman arm and went back to a XJ drop pitman arm. I'm a little nervous about the XJ drop pitman arm, because even though they're both from Crown/Omix/whatever their name is... the XJ one looks Chinesium. If the bumpsteer is too bad I'll have to get one of those stupid expensive Teraflex knuckles.
I had to do a lot of grinding to get a modern steering stabilizer to fit, including on the ARB diff cover. I milled the taper so it ran as deep as possible in the tie rod as can be seen by the cotter pin hole being worthless... then made the stud shorter so it crushed the bushing more... then welded a disc on for the retainer... then still had to grind on the diff cover. Rancho RS77407 steering stabilizer may be too stiff, it actually significantly slows steering.
Still need to set up the air compressor, rebuild the spare NP231 and put the SYE in it, and then it can have 1310 CV shafts front and rear. Then I'll probably just drive it until winter and then do the body work.
The geese on the pond do not care for it.
Took the boss lady for a ride in it with the dog around the yard and the wider trails since I don't have plates or insurance on it. The dog doesn't like it much because he can't see out the windshield well. She didn't like that it rides so rough. It does. I told her I wanted to buy a LJ but she said no. So now she wants to sell it because at least the TJ/LJ has airbags. I said that it's basically a large garden tractor so it's dirt simple and that's the tradeoff for something that rides rough and weighs nothing. It's not supposed to be a daily driver.
I am hoping the springs break in a bit. They sit an inch higher than the clapped out springs I had on it.
