The Michelangelo Update
I'm calling the Michelangelo update because all this work was completed on my back, on a creeper or the floor. A rotisserie would have been nice, but I plan on only doing this once. After cleaning the entire
underside with a wire wheel, surface prep disc, sanding sponges, and wiped down with lacquer thinner, the surface was primed with Raptor acid etch primer. The nozzle on the cans sprayed a flat fan pattern, so it was easy to rotate the can to get into the nooks and cranny's. This primer sprayed very easy with no runs or nozzle drips, upside-down.
Next was applying 4 bottles of black liner. Once again the liner laid down nice for spraying upside-down.
Finished connecting the fuel, vapor, brake lines, and e-brake cable. Just have a few more items to check off the list before placing the tub back on the frame for the last time. Yea!
