1ton brackets for 80's K5
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
These are front spring hangers for the rear suspension on an 80's vintage K5. DIY4x built these to be used along with 1-ton shackle flip so that a 1-ton version 14bolt is a direct bolt in.
I ran these for 7yrs in the General. I would like $50 shipped (lower 48).
Located an hour north of Denver if you want to meet up for the transaction.
Hmm how does a 14B know what spring hanger is being used? How do these make bolting in the axle easier I'm curious?
because normally when you put a 14 bolt full float from a 1 ton under a k5/10/20 you have to cut off and move the perches in. the 1 ton frame is wider than the others so this will space your springs out enough to match up with the axle instead of matching the axle to your truck .
Oh ok I gotcha now. The spring perches are wider than 3/4 ton and 1/2 ton that's right.
:waytogo: yup. its either change the truck to fit the axle, or change the axle to fit the truck.
these are a part of the first way.
Yep. My 14bolt has the older cast style perches which I've heard are especially difficult to remove. I needed a shackle flip too, so I figured why not do the flip in a 1ton version and DIY4x made me the front brackets.
I guess I felt like removing rivets was easier than the perches. Which is probably debatable. I also like it because it was different. And the best thing is with my new crew cab project the 14 bolt was a direct swap.
with the right removal tools id agree.
