For sure fans can have way different efficiencies. I’ll have to measure one but they aren’t more than 12”, and each one will pop a 20A fuse when it turns on at full speed. It was the reason I needed a PWM controller so I could slowly turn them on.
I agree, S blade fans are more efficient than straight blade fans, and some motors are more efficient, but two S blade fans of the same diameter both brushed motors, no way does it flow the same CFM at half the wattage, especially when they come from overseas. I trust the US made fans. I'll know this week if it fixed the issue, it's supposed to be 97 this week.
Those fans you have that will pop a 20A fuse surely flow way more than a 8A fan of the same size, that is what I am trying to say. If he has some overseas fans with low wattage, they aren't enough, despite what airflow they claim.
By efficiency I am talking cfm/watt or cfm/amp in a 12V system. Those overseas fans claim 200 cfm/amp, and the Derale are 95 cfm/amp, I believe the Derale. If they are both telling the truth, then 4200 cfm vs 4000 cfm won't change anything. I bet the overseas fans are more like 2000 cfm, which is not enough.
The fans in my regal use over 20A per fan no question, and the fans in my truck are close to that, I think just under. When I had LS fans and a small block I could feed them both with one 30A fuse, but not the windstar fans I had to go to with the big block, the LS fans wouldn't keep it cool. Hooked up windstar fans and it popped the 30A fuse. Upgraded the wiring and the problem was solved.
Also, when they put louvers in the fan shroud, that reduces the effectiveness, because the fan can just pull air through the louvers and blow it right back out, and that air never goes through the radiator. Derale has flaps that only allow the air to go out the vent, but not in.
I also set the fans to turn on/off at 5 degree different temps, so they don't both turn on at the same time and pull down the electrical system.
