I know about the reverse rotation of the serpentine, sure I bought the water pump for the later model engine. I think it would have fully overheated if the rotation was wrong. Isn't there an easy visual difference in the 2 pumps?I have to agree with most here there's something not right, you shouldn't have that much trouble cooling it.
I would first doubt you Chinese fans are doing their job but don't dismiss the whole system, make sure coolant is flowing properly, no restrictions, water pump with correct rotation and no air in the system.
When I changed the t-stat the radiator was totally full and it had burped into the overflow tank. The upper hose also felt like it was full of coolant.
I am pretty sure it needs real fans. Hard to not try them when they are almost free in a package with the radiator.
