@500$k5 is correct. 12v to the F (I) terminal makes the alternator charge.
Strange 2nd problem:
With the gauge cluster out, the pink wire that previously fed the coil has 12v with the key on and 5v with the key off. Using this wire for the proflo4 switched power signal caused the relay to energize. 5v is enough to trigger the relay. Removing the 20a gauge/idle fuse makes the pink wire 12v key on and 0v key off.
It also fixes the same issue with the fuse block tap for ignition. Going to use it this way for now and see.
Trying to keep everything working with the key and not need a toggle switch for anything.
Electricity is still hard but I'm winning..... I think.
