Ya, eh!Welcome to Adulting, eh?![]()
I want to bring this over here as to no plug up Dave's thread.
I am planning on adding to my house and build a very oversized 2 car wide/4 car deep garage.
Something like this.
Cool. Looks like a fun project.
And did you just publicly post your address online?![]()
On second thought, you probably don't get enough rain down there in the desert to care very much.
Thoughts from the background:
1, that hip roof would drain better if the seams had been lined up.On second thought, you probably don't get enough rain down there in the desert to care very much.
2, I'm trying to decide whether the tracks I see are agricultural or just someone out screwing around. Probably the second one.
3, your mismatched truck bed is visible from SPACE, fer cryin' out loud. Although I do have a satellite view showing my truck before I installed the wooden floor boards (so you can see through the bed).![]()
4, butting up to a hip roof is tricky and sub-optimal. If you just add the yellow box you will find water running toward your new shop (assuming that the shop at least equals the house height).
4. The more I think about it, the more I want it slightly back, as to access the back side of the house easier. That will also reduce noise and vibrations on the house, while working late in the garage.
So...not attached to the house?
1. Not sure what you mean by the seams lining up. The Google picture is at a slight angle, so things may appear to be distorted.
Yes correct.
I always thought something detached about 8-10 feet from the house would be good. Seperate the noise, but close enough to not get too wet if it is pouring rain when you decide to get back to the house
