One-eyed butt pirate?!?!??
I don't even know what that is. Must be one of those Wyoming things.
I bet, my wife just loves breaking down/running out of gas/getting stuck in one of my trucks, all of which i have done with her multiple times.Just drove back from KC with a failing alternator and hardly any head lights. Gauge was showing between 9 and 10 volts. Thank God for dual batteries. Was in blackout mode inside with no radio and no dash lights. The wife was getting a kick out of it.
And I’m back on this truck tonight. Decided I would go ahead and replace the bad alternator tonight with a good low mileage unit from work. In the process of replacing it, I tried to burn the truck down. I got in a hurry and forgot I was working on a diesel with dual batteries and left a hot wire laying on my ac line. After about 5 seconds I noticed some smoke and then tried to remove the wire only to lose grip and have it arc and bounce around some more on the ac line. After a couple seconds of that I got ahold of it with some pliers. Once it was secured I disconnected the OTHER positive terminal and assessed the damages.
Ac line is scarred, but fine. The wire to the back of the alternator is fried in multiple spots. Part of the lead had melted from the battery terminal and soldered everything together.
Got most of the wiring separated and ready for a new wire to the alternator. Going to pick up some solder and heat shrink to do it right tomorrow and put it back together.
Man, we all have days like that.
I should have the battery & alt wiring off of a 95 6.5 I parted in good shape.
It's yours for shipping if you're interested...just pm me.
I've done about the same, and know well the feeling of frustration that immediately follows. Glad all is okay....After about 5 seconds I noticed some smoke...
I should be able to salvage this. I'll let you know either tonight or Thursday if I save it.Man, we all have days like that.
Yeah, I was surprised that the link was still ok. But the wire from the link to the battery is only a 14/16ga wire, where as the wire from the link to the alt is more like a 10ga. Not sure why they did it that way. Usually I don't have this issue, but I have been working on nothing but gassers for the last few months.So...you melted your wire and didn't blow the fuseable link?![]()
Spend the $7 and get battery disconnects.
Yes, I am missing some threads. If you go back to the picture of the positive terminal, you can see that the bolt was not seated all the way into the terminal end. So once I got the bolt in there correctly and there is more than enough thread contact now.I'm impressed you were able to melt the copper and lead without melting the aluminum tubing. If the battery terminal is missing metal you're probably missing some threads. A longer 3/8" bolt with a jam nut is also a good idea. Give those few remaining threads a chance of surviving.
I should be able to salvage mine, and if that's the case it's all yours.I'm interested if he's not.
Yeah thanks. It's one of my better electrical fumbles.WOW.... That's some impressive carnage.
Yeah, a 15min job turned into a multi-night project. But the good news is I did find some issues I didn't like, and I get to brush up on my soldering.I've done about the same, and know well the feeling of frustration that immediately follows. Glad all is okay.
David
....pew pew
What type of picture would you like? Camper? Hauling a crawler? Maybe just a glamour shot in the ditch?We need more pictures of this truck doing truck things....
....pew pew
Go for it!Sounds like @GWeakland620 got things figured out.
I'll get some pics today/tomorrow & PM you.
What type of picture would you like? QUOTE]
How bout frame deep in some Kansas mud?
I have another truck for that, even then I'm out. I hate mud with a passion. It's fun at the time, but I loath the clean up and mess it leaves.How bout frame deep in some Kansas mud?
