How far up are you wanting to go?
There is usually only a little bit that you can go up with the front, before hitting the stops for droop or using all of the bolt.
This is based off of typical stock height. I have seen some trucks which had work done to them, which are too low and sitting on the bump stops.
I have adjusted mine as well as a couple of others which weren't set well, some low, some too high. One was so high that it rode terrible. It was topped most of the time and nose high.
