OK so my daily atm is a 14 Silverado with sb ext cab and the aluminum 4.3.
Lovr the truck but last year I threw a set of Rancho +2" front coil overs and rear shocks spec'd for this truck. At the time I also did power's top front rotors and ceramic pad.
Since then I've had it aligned aits always had a terrible vibration after 68mph.
Last night I replaced the oe rear rotors and pads as they were about done as well. Still vibrating. I'm starting to think these adjustable Rancho shocks, even tho they are on the lightest setting are the culprit.
My bed is unloaded most days so maybe they're too heavy for this truck? I still run factory steelies and one size up Yokohama at's.
Anyone have similar issues? I'm considering going with a different rear shock next. It's not a big deal but fairly annoying.
