203 removal
sandawgk5
3/4 ton status
Kitsap County PACNORWEST
So say there was a junkyard and there were a couple of 203s in some of the vehicles. Would one person be able to drop one with out killing said person? This would be a dirt junkyard and the person removing it does not have the access to a floor jack.
Thanks
Ira
beater_k20 said:
i'll come to your funeral after you attempt it.
Who said it was me:D . I kinda figured as much that why I did not attempt it today. I did get me another set of 56s and they had a Dually Dana 70 from a 92+ Cheby just begging me to pull it.
Ira
If this said person is only needing the range box then just unbolt all the bolts and jump back quick before it lands. Not much going to hurt the cast iron case of the range box. :thumb:
The one I was gonna get had 2 crossmembers and someone fabed a skid plate between them. I was gonna let it sit on the skid plate and then unbolt the mounts and let it drop. Oh well I am home now and really sore and tired. I did not have the proper socket for GM ubolts so I removed them with my crescent wrench:doah: . But the spring hanger bolts slid out by hand and the truck was a 76:D .
Ira
in a word..DON'T!!
I've done a few on the dirt,and was lucky to still have all my arms, legs, and a skull after that....had to just pull it and let it drop onto a peice of 3/4" plywood ,then use a riding mower to "tow" it out from under it!..I bet a 203 weighs 150-200 lbs easy alone,not counting the adapter!..even TWO people would have diffuculty doing it in a junkyard on dirt..more chance of doubling the injuries recieved really!..
In a junkyard situation,I'd say let them yank it out for you,or at least do the lifting ...--they will probably lift the truck up with a forkloader ,and prop it up on another car,or flip it on its side,and use a chain and the forklift to pull the T-case after removing the bolts ,etc...its not worth getting your skull or chest caved in for!...:crazy:
I did it myself without a jack. unbolt all the bolts from the trans and linkages. then throw a tire under there for it to land on if you need and unbolt the cross rail from the frame. remeber to jump back when it lets go:) I just dropped mine on the ground and dragged it out since the tire under it would have put it to tall to slide out from under the Burban I was pulling it from.
just leave the x member in and before you take out the bolts, prop it up like the pic... remember you will have to do both sides this way... :D
That would have worked also. The two crossmembers and skid plate are factory and not home brewed. I used to have that same set-up on my 76 blazer.
strung el cheapo straps under the front and rear output. unbolted and shoved off. didn't hit the ground either lol.
I did one out of a '76 wasn't bad at all. this was in the snow in early spring. dragging it wasn't the problem........having the frame 2" lower than the lowest spot on the 203...now that was a different story.
....and its not all that bad.......I lifted the new 203/205 doubler out of the back of my dodge today and set it nicely on the garage floor......cause I don't have a hoist just now :crazy:
I have done several to get to the adapters and it isn't to bad, just be somewhere else when it drops. I usually left the adapter bolted to the trans less work and on single crossmember trucks you can unblolt all of that stuff after you push/pull the t-case out of the way.
