241/205 doubler
Hogback Fabrication
1 ton status
Vendor
New Castle, CO
I needed lower gearing for the buggy and wasn't going to drop the coin for an Atlas or Stak. I didn't like the weight, cost and gearing options of a 203/205 so I settled on using ~1/3 of the housing from an NP241 and its 2.72:1 planetary gearset as a reduction box which transfers power to an NP205 transfer case.
The idea is to use part of the front half of a 241, just enough to support and shift the planetary gearset inside. The NP241 gearset is VERY strong and is used in many other applications; the 4 speed Atlas, Klune V and NWF Black Box all use the 241 gearset.
I like this idea because its light (40 lbs., a 203 range box and doubler adapter is ~110), has good gearing selection (1:1, 2:1, 2.72:1 or 5.44:1) and its cheap.
Here are the hard parts I started with, an SM465 (32 spline) bolted to a 465/(208/241) adapter bolted to a passenger drop NP241 (also 32 spline). I'm also using a round pattern NP205.
I had to buy a blank clocking ring and drill/tap the holes myself to clock the transfer case upside down. You need the larger part of the case on the opposite side of the t-case drop i.e. with a passenger drop transfer case you need the bigger side of the reduction box on the driver's side.
T-case w/clocking ring:
Now cut the front output part of the housing off, its not needed:
And the piece that's removed:
I decided to build my own adapter because Duffy (D&D machine) wanted $270 for it. I spent $50 on plate and about 4 hours to make mine. Duffy has stopped making 241/205 kits but he does make 231/205 kits and they are similar (pics/explanation at the end)
So I put the 241 half onto a piece of .500" aluminum plate, traced the pattern of the case and cut it out with a 4.5" angle grinder.
Then I eyeballed where the mainshaft would pass through the rear of the case (you can see the sharpie marks I made) and cut a hole with the biggest hole saw I had (2.5")
Here's most of the cost of this project, the intermediate shaft that couples the 241 to the 205. I got it from D&D machine for $250, its chromoly and its 31 spline (I'm using the 31 spline input from a Ford 205 that I cannabilized for its 32 spline front output).
I removed more aluminum from the plate using a hole saw:
so that I could do this:
I put a new seal in the seal retainer and slid it over the input shaft I'm using. I supported the input gear to center it the best I could and using this as a template, I spray painted over the seal retainer to get a pattern that I could cut into the aluminum
The hole that is cut in the plate has to serve as a pilot for the seal retainer, it basically insures that everything lines up correctly. The hole in the plate has to be just a few thousands of an inch larger than the seal retainer.
Here's the plate with the hole cut in it (not too bad considering I ground it out with an angle grinder)
I didn't take great pics of this part but the rod that supports the shift mechanism has to be cut down to fit inside the case half. I drilled and tapped it (1/4") and drilled a hole in the aluminum plate so that the rod could be supported on both sides.
I bolted the plate to the 241 box and bolted it to the 465. Then I put the input gear and seal retainer onto the 205 case, slid it onto the 241 output shaft and clocked the 205 flat. A few of the six holes that mount the 205 are drilled all the way through the case, so I marked them on the aluminum plate from the inside of the 205 case. Then I used my clocking ring to drill the rest of the holes. You can see the fill and drain plugs (not tapped yet) and the little hole for the support for the shift rod.
Here's the whole thing put together:
40 lbs. all together, a 203 range box and doubler adapter is ~110 lbs.
Bolted to the adapter
To bolt it together you have to bolt the plate to the 205 case first
And done
I still need to cut and weld a couple pieces of aluminum plate to fill the holes where the front output was cut off and of course make new crossmembers and a skid plate. Because the 241 box is upside down, I'll need to weld up the hole where the vent used to be and drill a new one in the top. Everything will be shifted via cables.
One of the shift rails on the 205 interferes with the 241 box, you can either notch the 241 for clearance (like NWF chose to do, look here) or you can shift the 205 from the rear like this guy did.
You might think that the aluminum case is a weak point but its not if the t-case is supported correctly. That case is ridiculously strong in torsion, but its not hard to break stuff with a heavy 205 hanging off the back (same reason there are so many 465/205 adapter failures and so many auto transmission case failures).
Total cost was about $300, $250 for the shaft and $50 for the aluminum plate. I got everything else for free, but they're not too hard to find for relatively cheap.
I had both a 241 and the front half of a 231 in my possession and either can be used. They both use the same size gearset and you can interchange them. I chose to use the 241 front half because it has more ribs and the case is a little thicker.
For comparison, 231 vs. 241
6 gear planetary (241) vs. 3 gear planetary (231), they are directly interchangeable
231 case vs. 241 case
Nice work :waytogo:
You are a very dedicated man, thats a lot of cutting with a grinder, and to get that hole round to fit a seal.
Lots of good pics.:waytogo:
I like these ideas. Keep up the good work. I might do this some day.
Tarey
Dude... $300 for a doubler...?! :bow:
i need to look around my junkyard for a 241... what did they come in...? (years, models...?)
thank you for this work, i'm subscribed, and i'll be printing it all out...!
ALSO - what year 465 do you have...? i'm getting one out of a '72 Chevy 1/2 ton 4x4 at my local junkyard, and taking the 205 that it has too... would i need a different spline output...?
The hole doesn't fit a seal (I would never be able to grind a circle that perfectly). The hole has to match up with the aluminum housing that holds the seal, so little gaps aren't a big deal as long as the hole keeps the t-case centered.
88' and up Chevy trucks I think, most are driver side drop (which is easier than flipping a passenger side drop one upside down like I did).
The one that's in the truck now is 10 spline, it won't really work with this setup.
The one in the pictures is 32 spline (the 465's from the 80's are generally 32 spline), the 241 is also 32 spline and they're connected by the factory adapter.
Wow! Great write up and ingenuity.
Gotta ask, how much do you have into the setup with both t-cases and then the applicable parts for the build? (granted, you already had 1 case)
The trans and adapter were $100, the round pattern 205 was $75 I think. The 241 was free (a guy here in CO was parting out a 3/4 ton Suburban). My current 10 spline 465/205 is worth a couple hundred, so I consider that a push.
The 31 spline input was leftover from a Ford 205 that I used for its 32 spline front output, I bought that case for $75.
I have a th400/np208 PSD combo now. I also have a NP205 10 spline from a 465 I belive. If I buy a np241 case will I be able to make the doubler from what I have? If not what cases should I get? I would love to have the lower range because my set up now (4.56 gears/38.5 tires) isn't quite low enough for rocks.
Does D&D have a website?
You could also use the 208 as the reduction box. I've heard that the planetaries in them aren't as good but I don't know why.
As for using the 10 spline 205, the figure 8 pattern probably won't overlap onto the aluminum plate. Also, I don't think Duffy makes 10 spline intermediate shafts.
I don't think so, but he is a vendor on pirate
That's awesome dude, I just signed up here after buying a 79 short bed 4x4 Scottsdale, and this is exactly the info I was needing, I was going to do the 203/205, but this is much better, Thank you for this great write up..Salt-Man (Rick)
I will be doing my write up today. Mine is a 231/D300 But the 231 is 6 Pinion .
I feel like crap otherwise it would be done already. Build the damn thing 6-8 Months ago.
Cool, I look forward to reading it, I have been mostly on Ford sites lately, and I love to read and learn as much as I can about the vehicals I own
what are the advantages of doing the one you did, I hope you feel better, this winter has been a ruff one around here..Salt-Man
:waytogo:
Anyone know how much added length in a 203/205? I'm guessing more.
I'd have chickened out and saved up for Duffy's plate. :o Assuming they are obtainable.
BTW, I don't think D&D is a pirate vendor anymore (unless he has come back). Edit: He IS back. :woot:
