28 DAYS TO MOAB !!!
Re: 20 DAYS TO MOAB !!!
You should drive it across Kansas during the day, just to get accustomed to the heat that is going to greet you in Moab! /forums/images/icons/wink.gif
Re: 15 DAYS TO MOAB !!!
I hope you and your pit crew there can get it together in time /forums/images/icons/grin.gif Your woman dont mind all the time yer spendin with the K5 does she?I know mine is kinda bent at me for the time Im spendin on mine right now /forums/images/icons/grin.gif
"YOU CAN DO IT!!"
I am expecting my pretty new High Angle front driveshaft to be waiting for me at home today. Cant wait to go and put a barber pole in it to match the other one. /forums/images/icons/grin.gif Other than that I am just tightning bolts and hoping for the best. The truck has preformed flawlessly so far this year. Who is going to want to take on Potato Salad, escalator, and Dump Bump early Friday while everyone else is arriving?
Tim.... You got a taker on those! I'll be hitting town sometime Thursday, so I'd love to try Potato Salad Hill on Friday morn.... just don't know where it is... /forums/images/icons/confused.gif
We'll need to hook up somehow. /forums/images/icons/grin.gif
Marv
We could just meet up at City Market and I can take you there. Says 7:30 so we can beat the heat.
Sounds good but you have to help me switch my steet tires to trail tires either Thurs night or real early Friday morn. /forums/images/icons/grin.gif
As long as I get there thurs night ,Im game for a fri morning run /forums/images/icons/grin.gif
scott and adam of las vegas...
trying to get your kits ready and mailed so you have time to get them installed. will be maile dout thursday hopefully.
Jason, your bump should be ready for a met and great to get you ready too.
-Jeremy
sorry for all the delays
Re: 14 DAYS TO MOAB !!!
Oh my GOD! We leave for Moab 2 weeks from today!!!!
At least I am getting closer to the "Put It Back Together" phase now.....here's what should be arriving by UPS in the next few days:
Borgeson:
Borgeson Steering Shaft
Boyce Equipment:
Dana 60 Spindles
Warn 35-Spline Hubs
Randy's Ring & Pinion:
D60 Bearing Kit
D60 Kingpin Rebuild Kit
ORD:
35 Spline Stub Shafts
New U-Joints
Misc extra parts for Crossover
Summit:
New Comp Cams 4x4 grind cam
New Lifters (16)
Engine Manifold Lift Plate
Total Auto Supply (Fremont):
Complete Engine Gasket Kit
Complete Rod Bearing Set
Complete Cam Bearing Set
New Piston Ring Set
Donations from 4x4HIGH (not really, but cheap):
Steel 396 Crank
Set of factory 1.7 Stamped Rockers
JD Offroad:
TireLoc Beadlocs (Set of 5)
Good thing I still have a job (paycheck).....I've been spending WAY more than I should to get ready for Moab!!!!
So I'd better be able to go.....dammit! /forums/images/icons/grin.gif /forums/images/icons/grin.gif
Holly Molly DudeAramma!!
You are a MADMAN!!!
I ended up geting sick from all this waiting around for MOAB!!! /forums/images/icons/crazy.gif /forums/images/icons/mad.gif I am way too excited for this trip across the desert!! /forums/images/icons/tongue.gif
Best of luck!!
tick tock tick tock!! /forums/images/icons/grin.gif
good deal jeremy! I am doing the axle swap this weekend for sure... gonna be crazy. /forums/images/icons/laugh.gif
J
So what was the cause of yer oiling troubles?Is that whole list gonna be done or just the engine?
Good luck,use the force and all that good stuff /forums/images/icons/grin.gif
Frizz,
The latest theory is that the oiling holes on the Comp Cams Roller rockers are misdrilled....got that info from an engine shop that has heard a few reports of it. If you compare a stock "stamped" rocker to a one of Comp's rollers, you'll see that the hole in the stock rocker is drilled at a noticable angle, and the Comp one is pure vertical. Also the offset in the pushrod pocket appears to be off too....!!!
Not sure if this is the answer, or it's a combination of that and a bunch of scored bearings bleeding off oil pressure from the top end.
And YES....unfortunately the ENTIRE list is going to be done before MOAB. That's not even all of it...that's just the parts I've ordered recently. I still have to mount and balance tires, cut fenders, fix a bent rear shock mount....install long travel Ranchos up front....etc.etc.etc..
I'm so screwed for time....I don't even want to think about it. /forums/images/icons/crazy.gif
And you're posting here instead of wrenching? /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif
Or is it "Hurry up and wait for parts" at this point?
Rene
This is my "job" time.....Hee Hee Hee Hee
I can only work on it when I'm home.
I'm also hurrying up and waiting.....for some stuff.
ps. You should see my welds these days, they look really nice. I am doing uphand welding whenever possible like you taught me. /forums/images/icons/cool.gif
Doesn't it suck how work gets in the way of important stuff?/forums/images/icons/wink.gif
Any pic's of your welding? Uphand is always stronger than down...but hard to learn! Congrats!/forums/images/icons/smile.gif
Rene
/forums/images/icons/cool.gifGreg :\
wooohaaa, that; to do list is extreme!!!
are you takin a second on the house?
looks like you need some personal time off.
A death in the family, old 396 may it R.I.P.:(
It will take a lot of midnight chanting resurrecting the beast.
Do you feel like your out at sea treading water?
With your list a stuff tied to your feet.
A storm is coming?
Is that whats troubling you Bunky?
Take a deep breath!
You may want to take two of those /forums/images/icons/wink.gif too...
I think in your condition 2 days off may not be enough!!
so you better take 3!!!!!!!!!
<font color="orange">dogman </font color>
Your gonna need a vacation after this vacation to recover /forums/images/icons/crazy.gif
13 Days.... Building the bottom end of my 396 tonight. Hopefully have it up and running by Saturday night!
Oh, and I forgot to mention in my previous list....I also have to re-gear the rear axle to 4.10 ratio to match the D60!
I think yer gonna make it /forums/images/icons/grin.gif
You already got the 4.10s or ya gotta order them?
