Last weekend I got a phone call from a potential customer that I met at the parts store. He said his 6.2 truck would not start. On top of that, it was broke down 1/2 way up in the mountains. I did a quick service call for him. The coolant crossover gasket on the passenger side blew out and the coolant ran down his motor onto the starter solenoid and shorted out. I swapped the solenoid and followed him home. Later fixed the leak, added a missing starter support brace, added a missing starter heat shield, drilled out holes in the intake box to get his N/A 6.2 more air and as always… I gave him a butt load of ideas, free diagnostics and a good reason to keep coming back! Sorry, no pics were taken.
Back to the red utility fire truck…
For only $31, I thought this turbo blanket heat shield was a great deal! Customer agreed! It only took me 2 minutes to put it on and it fits the ATS turbo perfect! I did not even charge the customer for that to be installed. Less heat in the motor bay the better!
Specificationsï¼ Outer Made From Pulverized Lava Rock (Tough Titanium Outer Fiber Fabric) Inner Insulation Made Of Fiberglass Wool Underside Made From Pulverized Lava Rock (Tough Titanium Fabric) Stainless Steel Capstan Rivets Stainless Steel Spring Fasteners Made From High Quality Materials...
www.ebay.com
I also installed the CUCV Paradoxbydesign kit to help keep the rear of the motor cooler. I routed the lines above the plenums to keep the lines cooler.
So the finial diagnostic is that the sending unit sock is clogged and the truck does not get enough fuel. I will get the tank dropped and see what is going on. Hopefully the inside of the tank is not all rusted out.
