$350 for (4) 37" Goodyear MTs?
Yeah thats not a bad deal at all. Theres loads of guys out there that are on drugs and thing theyre worth $125+ a tire...
You can buy them from trailworthy fab for $75 each. So if you could pick them up without too much gas you would come out ahead.
There is a tire shop here in fort worth that picks up all the take offs from the base in saginaw and they are selling them for 250 a set.
I dont understand where the people around my area get the idea theyre worth so much. You can buy a ****ing dana 60 front for $300 but hey **** hummer street tires are $500 a set!
Just picked up 4 for $300. Even told me I could bring any of them back if they didn't hold air. Load range D made in '03 and '04.
I have a tire dealer locally that also buys them from the military. He sells the tires in 80 percent or better condition mounted on a 8 bolt hummer wheel for 100.00 gets 125 for the 12 bolt/tire combo. Most are still mounted and balanced with the runflat in them.
I've never really had that good of luck with older tires like that, i used to buy them used alot in the past from tire shops and whatnot, cause i'd chew them up with some off roading i used to do, but the main problem i always ran into with older used tires, even with good looking tread, was they tended to seperate alot, especially with alot of highway use.
Now if/when i buy used tires, i usually try to check the date code stamped on the sides and if they're too old, i usually pass.
6-7 year old tires, i definately would have passed... just my opinion though.
Can you go back and pick up a set or two for me and store it until I can get them? Of course I'll pay you or the seller in advance.
Where in OK are you exactly? I have a buddy who frequents OK searching for derby cars and if you're not too far, he could probably pick them up for me.
Yeah they are $500 for a set here too. And I need 3
