adamforsythe
Ok I changed the dizzy, plugs, wires, carb 3 times, adjusted everything. Should I put a hotter plug in???? Please help. The truck runs fine for about 3 days of starting it and running it for like 1/2 hour then shutting it off. Well I just took it out I know my plugs where fouling but I needed GAS. So I went and got gas then went home. I ate dinner then I got back into the truck to take it back to the shop for the night. Well on the way (1 1/2 - 2 min drive) The engine started to miss fire and loose power I stuck it in N and gave it some gas so it could come out of it and it did. I put it back in gear and it did the same thing in tell it died. I pushed it out of the road. My step-dad came with the dodge to tow me. I tried starting the truck and it fired seemed to run fine. Then I put it in gear and it sh!t the bed. So we towed it back to the shop. The engine is a 330-380HP 350 with a edelbrock 600 cfm carb, Newer edelbrock intake, headers, 2.5" exaust. Tayler custom wires, A NEW HEI dizzy.
Adam
Adam
