jeepthrillz
hello people , I really need some tech help on my 1 t0n 91 chevy crew , hopefully some one can shed some light this way cuz its very dark here,
This is the senario got a 1 ton chevy crew 350 tbi 4L80E 205 , swaped in a 454 tbi every thing fit nicely except for the iac and the tps , the 454 is out of a 1989 sub 2wd , the engine fired up at the first crank every thing is runing nice at idel and at acceleration i park ,the problem begines when i put it in drive and start drive away and try to accelerate the motor starts to stumble and hesitate and puts as you try to wot it it just doesnot speed up,i checked just about every thing that i could think of , i used a pcm from a 91 dually with a 454 and 2wd 4L 80E it starts right up i also tried my stock 350 pcm w/ 4l60e but i does the same thing , I was told by tom at turbo city i orange county that i could use either or they both would work, does someone have any suggestions on what may be my prob, thanx
speed sensor is hooked up didnt even touched it when i swaped motors, my 60k miled 350 ran better than this 80k miled 454,o it has good compression,
