38.5 super swampers on/ new question end of page 3
Yeah hacking and flexing via my buddys fork lift with lots of pics!!!:D
the 2.73s gm just wanted good MPGs. But what can i say its gm they do some crazy things like make the best trucks ever.:D
Dude, I just read your sig...you really don`t plan on locking that front 10 bolt, do you?:crazy: You`ll be lucky if it will last open
lock it, i ran a tru trac in mine for 4 years, you just do MUD so as long as you keep out of the ruff stuff and dont jar the front you should do alright,its when you get off camber and hittn ruts at full throttle when you break the short side, for the cost of replacements, its alot cheaper than a 60, i also run 38.5s with ten bolts front and rear:D you will get good at a 15 min axle swap lmao
I love your advice thats wat i was thinking!:D
no, i havent rubbed the rear yet. i used tape and marked off how much to cut off on each side.
Chris, keep in mind he has like 7" more of lift than you do...
Hes got 4" more then me.
Ahh, I thought he had 8 inch suspension, 3 inch body...either way, you`re gonna have a hell of a lot of trimming to do:crazy:
sawzall for the fender / inner-fender supports and a grinder to smooth out the arch
You must have a good motor then, cause with 4.10 i can only spin the tires on wet pavement or mud. Definately doesn't put me in my seat. I don't really drive my truck unless its going straight into low range because I am undergeared and i don't want to kill the tranny. Overdrive is useless in my truck just like ryoken said. I want 5.38's or 5.13's and i think youll like them too and your tranny will thank you.
