I looked into this because I was curious, you guys are correct, all the one piece seal engines are indeed externally balanced, I am surprised, good to know. Even the balancer is, but the weight is on the ID of the back of the balancer, so it's not very obvious.
I was also thinking, and I think this is not common knowledge for a simple reason. Because they changed the flexplate bolt pattern at the same time, there are no internally balanced flexplates with the new bolt pattern. So unless someone removes the weight or makes a custom one, it's near impossible to put the wrong flexplate on there since if it fits, (and it hasn't been modified) it has to be the correct one. So unless it's a custom internally balanced crank, there are no interchangeability issues to worry about on the flexplate with the newer engines. Thank you for the info.
