398HBX
Frame is Painted!
I think I beat the weather. It is supposed to get colder starting this week and I was a little worried about getting the frame painted before the cool weather set in. I "got-r-done" tonight. Eastwood states to use a 1.3mm tip with their epoxy ceramic paint. I don't believe it. Should have used a bigger tip. The spray pattern was not that large and I had problems with consistancy on the spray pattern. Maybe a 1.4 or 1.6 would have been better. Anyway, It's done. Once it drys I can start putting the new springs on. Then it is on to rebuilding the axles. Has anyone here rebuilt a GM 14-bolt 9.5" SF axle? If so, what parts/supplier did you use?
