398HBX
14 Bolt SF Rear Disk Brake Conversion
Oh man, the wife is NOT going to be happy. I started to work on my rear axle and finally made the decision to go ahead and do the rear disk brake swap. After much research, I went with the TSM rear disk brake conversion kit (www.tsmmfg.com). The kit with rotors, non-ebrake calipers, and braided flex lines was ~$800. So much for my tax return......
) For the first time in 15 years, the Blazer has a body!
. I used the Energy Suspension body mounts and ORD 1" body lift pucks. I threw away the original body mounts years ago, along with the metal sleeve inserts. I checked out the local pull-a-part and was able to get some off of a 76 K5. $3 for all six. I also found the "correct" K5 fender emblems for a 73, for $3 (hell yeah!)
