3D Printing Projects - Truck parts and tools
That's a slick update on sticking the two parts together. Thanks for sharing it!
After some more poking around I figured out what I was missing with the files. I joined the 3d printer scene back in 2016 and everything then was stl files. I'm just a hobbyist and boot up my printer a few times a year and haven't stayed up to date as the technology as progressed. The stuff you've uploaded is 3MF and is a newer format than I am used to and contains different info than the old stl files did. My old slicer software only works with stl and I couldn't decipher how to break down what you uploaded into individual stl files.
For anyone else not used to the 3MF format you can load it up in Bambu Studio and export individual parts as stl files to print them out one by one.
DO NOT print that yet. I just realized that is the 77-80 version in the wrong print profile.
I have remembered why I only dust off the printer a few times a year. Troubleshooting warping issues is the worst. This is ABS.
Here is what my 10 year old knock off of a knock off Chinese qidi tech 1 spat out. It's a great 10 footer, but is warped real bad on the back corners and has separated a few places in the layers.
Try rafts at the corners, higher bed temperature, and/ or a glue stick for better adhesion. Is your printer enclosed?
I'm printing at 110 bed temp and yes it's enclosed (although not great). I'll play with the rafts and I may consider wrapping the enclosure in a towel to keep the heat up.
So is anyone doing this for $$$?
I need a custom duct made for the footwell off the heater box
I would do it you need someone, time and materials.
And yes it can only be as accurate as the dimensions given if I am not there. Unless you have a part you need replaced you can send.
That’s just it. I know there is a duct that went there, I don’t have it, no one does. I’m not even sure what it looks like.
So, I’ll keep my eyes peeled on the Eghey. I think it’s called a “footwell heater duct” specific to the 73-78 trucks, not blazers or subs
Is it just the duct that screws to the bottom of the heater box and directs the air out and back?
I think I found one on the Eghey.
It attaches directly under the heater box on the bottom side very close to the center position. It directs air out the bottom-center of the heater box to the footwell area.
I purchased it as soon as I saw it.
