4" Lift w/One Ton Swap / 37" Tires.....Seems TALL!
Yeah I know. I wish it was that easy to just remove them. The front wouldnt be so bad but the rear had the leafs plus all the factory "shims/spacers/whatever" between each leaf and was a PITA to get the center pin thru while it was on the bench. Cant imagine in a truck! Lol.
I look at it this way.....Ill have more room for bigger tires.
I use C clamps to keep the spring from moving around before I even unbolt the U bolts
Unbolt and remove, adjust the pin length, done!
