4" Lift w/One Ton Swap / 37" Tires.....Seems TALL!
If you want, a .25" X 1.5" piece of steel hammered and formed can be welded to the outside of your diff cover to protect the ring gear. I would incorporate something to keep the bottom holes on the rear flush so the rocks can't peel it open
I usually grind the bottom of 14 bolts smooth but didnt on this one. I might get under there and do that during some down time waiting on the rear driveshaft.
If you don't buy a cover, reinforcing that one before you grind is a good idea. Never got mine to stay sealed without protection on the lower 3 bolts. I also used header bolts. Wasn't much left on the bottom when I sold it
Yep, good idea. I would leave 1/4-1/8" extra just to protect that lip
I'm going thru the same thing. Installed a 4" lift and zero-rates and the truck seems way higher than I expected. I had it stock for about a year so maybe I'm just not used to it? These are 36" tires. Looks like our trucks are about the same height. IMG_0621-1.JPG
Exactly. From what I read I was thinking I would have to do the little 1" body lift and cut the crap out of the sheetmetal to fit em. Kinda wishing now I woulda left the zero rates out. Id rather cut a little and have a lower COG.
:dunno:Now I have no actual proof, but more than once it has been suggested that there is more lift compared to stock because the stock springs are sagging more than we realize.
So I guess that if there is some truth to that, then fresh lift springs will make the change more dramatic.
But also remember that the larger axle tubes give a lift as does a D60.
Stock push pull with ORD steering brace and ORD drop pitman arm. Not looking to do any hardcore rock crawling just trail riding around the Rockies. Didnt want to spend the money on cross over at the time. Hopefully I dont regret it.
I take it you didn't move the axle forward any? I have the same springs and zero rate and plan on moving the axle forward 1.5, can't find a straight answer on which crossover will work. Guess i'll just call ORD monday and talk to them.
I like the stance on that. I am hoping once everything is bolted back up it sits like that.
Yeah Im afraid of that Big Ray! The front shaft already hits the exhaust but thats not big deal....exhaust was planned into this from just street. BUT it will just have to be lengthened so that wont be as costly.......allthought it would might behoove me to change out to 1350 joints.
Honestly think 1310 will work great. Never had any issues unless something was amiss in the set up
