handloader90
Building!
Truck details.
LWB '73-'80 frame with an '82 2WD Cab and bed sitting on it.
350/TH350/NP205 D60/14FF
So I was making a build sheet in Microsoft Excel, inputing the items that I needed and their cost.
I was adding things up and ended up getting an email from RuffStuff which had their combination 4 Link brackets in it and they sparked my interest.
I have a few questions on this:
1) Can I use regular shocks, like some nice Bilsteins vs. using a coilover or strut?
2) Inboard vs. Outboard on the shocks? Can someone use an x-member such as the DIY4X one and run the shocks at an angle?
3) Will a single triangluated 4 link suspension eliminate wheel hop?
4) Does a single triangluated 4 link suspension eliminate the need for a track bar? I wouldn't want the axle moving around and tearing my shocks up.
5) What would the optimal wheel base be? I tossed around the idea of bobbing the bed but that may be out of the picture depending on how far forward the axle would be moved to achieve a better wheelbase. At this point the box would be removed, frame cut down and I would fab up some kind of "trail bed" made out of 2x3 tube.
Last but not least, is it worth doing?
I know that I'll need the following items:
Bracketry (frame, axle tube and top of truss)
Truss
Links
Heims
Limit Straps
Extended Bump Stops, possibly Air Bumps
Frame boxing
Shocks
Truss
Links
Heims
Limit Straps
Frame boxing
Shocks
