i left something out it had a starter button on it....there is a purple wire in the harnees(runs to the starter from the column) and the p o cut it and used a yellow and green wire
for starting the truck.
neutral safety switch was bipassed
i will post pics wiring carnage
thanks for the help guys
p s
the switch on automatic is on the column,manuels its right above the clutch pedal
