jonathon
That Ranger unit is pretty cool.. and $1500 seems reasonable. I wonder how shifting it would feel with the shifter moved back 7"..
That problem was fixed by the early 80's, and the fix is quite easy to apply to earlier 465's. Furthermore, it doesn't usually harm the tranny, and the fix in relatively inexpensive.
am still trying to find a total length of the 203/205 combo to compare.
I know, just wondering if anyone has any experience doing the 2 stick tango. Seems like it would be a little hard to get used too but not so bad once you did. Kinda like the dude in the video you posted with the Detroit driver. I think this is the way I will probably go in lieu of a 4500 after careful consideration.
if You Do The Ranger With A 203/205 Doubler (assume Long Wheelbase) And Twin Stick The 205, You End Up With 5 Shifters. Keep Blank Knobs On All 5 And You Have A Built-in Anti-theft Design.
do i need the transer case, or will the one behind my 700r4 work for me
So, I understand the concern about the nv4500 spittin out 5th. If i still am convinced that this is the tranny for me, do i have to get a nv4500 from a 4x4? do i need the transer case, or will the one behind my 700r4 work for me?
The 5th gear nut can back off on stock (mostly Dodge) NV4500's. There is no damage done and all that happens is you lose 5th gear. This is usually a problem on trucks that see a lot of towing.
There is an easy and cheap fix for it, especially if the trans is out of the truck.
Yes you need to get an NV4500 from a 4WD truck. As for which t-case to adapt to it, all the stock t-cases behind 4500's were driver's side drop.
You may be able to get a 4500/241 adapter and put a passenger drop 241 behind the 4500 (using 32 spline inputs and outputs, 1 ton Chevy stuff).
