great info man. I have changed from an auto to manual ('79 malibu t350 to super t-10) But i have never done a 4x4.
Also, im in Colorado, i bought my blazer about a month ago, then moved to colorado literally that same week. I will be flying to get it soon, So i cant exactly go look at it right now. (1986 blazer)
So, my k5 is passenger side drop, right? without a doubt i will need to get a new transfer case? is a "241 adapter" a stock part?
please excuse my ignorance, i have never owned a 4x4 before, and dont know too much about transfer cases, and the like..
thanks man
If your truck is stock and an auto, it will have a TH700R4 transmission and an NP208 transfer case. Yes, all K5's use passenger drop front axles.
If you want to swap an NV4500 into your truck, find one from a 4WD Chevy (basically a 90's 3500 4WD Chevy with a 5 speed). It will have a 32 spline output and would have had a driver's drop 241 behind it. The adapter behind the 4500 should work with either driver or passenger drop cases. Then you need to find a passenger drop NP208 or NP241 with a 32 spline input or buy a new input shaft for your t-case (its 27 spline).
