Looking for a 4spd hump/tunnel cover for a 73 and up squarebody.
Must be orange
@skunked and I were already talking about this. Can someone confirm if the automatic covers (t case hole only) are different height than the dump truck trans covers?
No body lift at all.body lift?
There are 2 different lengths/ styles. Blue is 77 and the longer black is about 84/85.
I had to shorten the black one and drill a couple of holes to mount.
https://ck5.com/forums/attachments/img_20190317_174711634-jpg.297876/
There are 2 different lengths/styles. Blue is 77 and the longer black is about 84/85.
I still have it and I think a couple others. I can get some pics tomorrow.Oh and where’s the blue one at?
I have a auto one from an 81It will be graphed into a early 70’s 2wd truck. I have a line on a 76 auto hump about an hour away.
By the way do you have the bolt on?A manual cover with the 205 shifter hole would be my preference. I’ll wait and see if @Capt Ron has one laying around first. Thank you.
I may still have the section of the floor to graft on as well
I will see what time I get off work today, if not tomorrow I don't have work so can look for it.sent you a PM
Can you check and see if you have that? I think that would make things easier for me.
Thank you
