Found 4 speed transmission tunnel cover
@Capt Ron will that fit a 1989? I have a suburban that I swapped out a SM465 with a NV4500 and the shifter is 4.5 inches behind the stock location of the SM465. I may go this route vise cutting a patching the shifter holes. How much do you want for is with shipping to 98277. Thanks man.
Not sure if it will work? This is from my 78’... its yours just cover shipping I guess... th350/203 is what I have
The blue one has been promised to Skunked and as far as I know 89 Suburbans do not have a removable transmission hump. Got pics?
@Capt Ron. At this time I do not and I am out of the country. Thank you for the reply. Thanks @Fastereddie for the reply. I got the boot and ring when I bought the NV4500 but it is huge and square and I wanted to use my stock NP241 shifter but it moves it too far back so I went with JBFAB buggy shifter but have not installed or did anything to it.
@skunked
What’s are you up too!?? I thought you were anti 465? :dunno:
I got a tunnel and pedals saved just in case. Not that it helps me being so far away.
@skunked
I got a tunnel and peddles saved just in case. Not that it helps me being so far away.
Never been against the manual but I don’t like them for wheeling. Needless to say, this isn’t for my crawler ;)
So you planning on using an sm465 or nv4500 or maybe even a n nv3500?
I have a couple of sm465s if that is your plan.
I have a SM465/NP205 combo with the linkage and pedals. I might end up needing some odd parts along the way but I have most of it.
