Or this
12 Crate Engines - Budget Crates!
Twelve Killer Crate Engine Deals for Every Budget
Stephen Kim Jun 25, 2012
View Full Gallery
Let’s go easy on the doom and gloom, OK? Sure, the global economy has seen better days, but as hot rodders, we’re accustomed to transcending adversity. As a group who’s collectively survived OPEC oil embargos and performance-straining smog laws, the current state of affairs is nothing. We’ve gone from 165hp Corvettes in the mid ’70s to the 639hp C6 models that are available today. Hot rodders are a stubborn bunch, and the industry has a way of adapting to our demands. For proof, all you have to do is check out the current crop of crate motors. There are tons of budget-oriented options that are out there, which is why we decided to round a dozen of them up for a closer look. Our search found two small-blocks that hit 400 hp for about $3,000, a sub-$4,000 LS long-block, and a 590hp Rat that comes in under $7,000. Factor in the money you save on shipping dozens of parts to your door, and the gas saved hauling those parts to the machine shop and back, and the value and convenience of a crate motor makes even more sense compared to building a motor yourself. The deals are out there, so let’s take a look.
YearOne 357
2/13
Nothing fancy here, just a good ’ol 357 small-block for peanuts that makes an even 400 hp and 400 lb-ft. YearOne is best known for making just about every restoration part imaginable for your classic Bow Tie, but the company also offers a line of value-oriented crate motors. This 357 is a perfect example. YearOne starts with a stock four-bolt block, bores it 0.040 over, and matches it up with a stock crank, rods, and a fresh set of 9.7:1 pistons. Keeping the cylinders full of air are aluminum heads and a dual-plane intake manifold. With a mild hydraulic roller cam actuating the valves, the combo puts out a solid 400 hp. The motor includes a timing cover, oil pan, balancer, and flexplate. Just slap on a water pump, carb, and distributor, and you’re good to go.
YearOne
800.932.7663 · yearone.com
Specifications
Cubes: 357
Bore/Stroke: 4.040x3.480 inches
Output: 400 hp and 400 lb-ft
Block: Factory GM iron
Crank: GM iron
Rods: GM 5.700-inch powdered metal
Pistons: Hypereutectic 9.7:1
Cylinder Heads: Edelbrock E-Tec aluminum
Intake: Edelbrock E-Tec dual-plane
Warranty: Two years, 24,000 miles
Price: $3,499
