Lets get that PCV system working properly before you spend any money on anything or take it to anyone. You'll be surprised what not having a properly working PCV system can do.
All you need to make sure of is that there is a PCV valve in one valve cover attach to manifold vacuum and the other cover has a "clean air" hose that goes to the bottom of the air cleaner assmebly. You CANNOT have any type of open air breather on either valve cover. If this means you have to use a grommet in each cover for the PCV valve and the fresh air hose and you need to pull a grommet to add oil then that's what will have to happen. Most valve covers had one hole in once cover and two holes in the other though so that you have a dedicated oil fill location.
I just finished this Big Block engine and I can't seem to figure out how to rig up and route the PCV valve system. I want to do this engine right. Can someone please help me with that.
Well, I'm not a mechanic by any stretch but you have the ability to build an engine like that and can't figure out the PVC junk?????![]()
Someone please explain to me how it can make any difference whether you take filtered air from the air cleaner base or a filtered breather. Seems like the same thing to me. I have been doing this all my life and have never had a problem running a PCV valve in one cover and a Breather in the other.
+1
4x4HIGH, I'm not doubting your experience at all. I just can't see the difference between air from the air cleaner and air going through the breather filter....help a brudda out!!![]()
Having the fresh air hose attached to the air cleaner like it's supposed to be will draw a vacuum across the hose and actually help pull blowby from the crankcase along with the PCV valve. When you run an open air breather that creates a vacuum leak in the crankcase (think about the PCV valve that is attached to manifold vacuum) so now the PCV valve cannot do its job. I don't know if you or anyone else who doubts me will understand but I know how the system works and the effects of not having the system set up properly.
