4L80E and sm465 same input?
muddybuddy
1 ton status
Northern, VA
i was wondering, since the 4L80E uses the long 32spline input, is it the same input as the 32spline sm465's?
Afaik, once the 205 changed to the round bolt pattern ('85+) all of the input shafts are the same.
haha im going to swap in the 4L80E and then run blackbox to the 205. im just checking to see if they use the same inputs on the t-case so that if later down the road i decided to swap in a sm465 i wouldnt have to swap inputs on the blackbox. thats all :)
Yup ya wont have a problem...
