I didn't doubt you! Just trying to figure out what boosters it will fit.
Is your booster stock for your K5?
73k5blazer said:I didn't doubt you! Just trying to figure out what boosters it will fit.
muddybuddy said:thats what mine looks like, i was able to bolt mine right up to my 88 k5 booster without any other modifications. are you trying to put it on an older truck? i guess theres a difference
Desert Rat said:Well, anybody out there every bolt up a stock 88 MC to an earlier Blazer to see if it fits? I'd hate to buy one and have to return it.
K5er4Life said:Im gonna go ahead and give this a shot, just ordered the master cylinder, it will be going on my 87...
muddybuddy said:hey all, ive got a 1ton k5 with 4wheel discs on 42s. originally i replaced my stock master cylinder with one off a k20 but that was still inadaquate. so i went to advance auto parts and started looking up master cylinders of various truck. im actually going to start working there within the week, and i know everyone so they didnt care if i ordered and then returned them haha. i wanted the p30 one, but i dont have hydro-boost. then i found it! it actually looks bigger than the p30 van master. Part Number 102754, its off a 1999 c3500 with 4wheel disc. i just installed it, (the lines are reverse) and wow what a difference, i cant even press the pedal to the floor anymore, and can lock up if i want to. just thought i would share my findings, as i know alot of people are looking for the perfect solution after goin to 1ton with discs.
, so I'll keep my eyes open.roadnotca said:Good question here for anyone thats an expert on brake design; can there be "too much" master cylinder?
I wouldn't mind coming to a screeching stop.
ntsqd said:Yes, there is.
It boils down to simple leverage. The bigger the bore m/c the less leverage you have and the less pedal travel you have. With enough booster this doesn't matter. Enter hydroboost....
With too small of a master you have all kinds of leverage, but too much pedal travel. Some of that pedal travel is used to distort all of the other parts of the system since you can now generate excessive line pressures.
This isn't a wide ridgeline, it's nearly a knife edge. Easy to fall off too far one way or the other.
Prop valves: It's been my observation that the shorter the WB and or the taller the tire the less a p-valve is needed. Friend of mine (Dremu met him) had a nearly stock flat fender w/ 4 wheel discs. All the same size rotors & calipers running off the stock single outlet m/c. Worked great.
Also, if I understood correctly for this m/c to work you have to swap the lines front to rear & vica versa. This is not good. The front brakes should be operated by the rear piston in the m/c. If everything is working correctly it may not be a problem, but when something fails it could become one. The reason the OE arrangement has the front brakes on the rear piston is b/c this piston is directly operated by the pushrod from the pedal. The front m/c piston is actually operated by the rear m/c piston. So the rear brakes don't start to operate until after the front brakes already have some fluid pressure.
roadnotca said:While we are re-engineering GM brakes, has anyone tried this on surfaces other than dry asphault?![]()
dremu said:I think the vacuum booster actually has more throw of the piston and is popping the seals on these masters.
What I was gettin at, I suspect, would be some experimenting with the proportioning valve so front to back apply like they are supposed to, especially in ice/snow/rain/mud. Wouldn't want to test with crush zones.RootBreaker said:id think that would be the hardest to stop on.. I dont see it being tougher to lockem up in sand, mud or in the trails....!!!!!
if it can handle asphault id say it will do on rocks too![]()
I hadn't seen this until now. Dry asphalt is the best case scenario, ice would probably be the worst. Everything is a compromise. You can set up the truck for heavily loaded on dry pavement & know that unloaded on ice is going to be an animal to control. You can set up for unloaded on ice & know that you're giving up some loaded on dry pavement braking ability.RootBreaker said:id think that would be the hardest to stop on.. I dont see it being tougher to lockem up in sand, mud or in the trails....!!!!!roadnotca said:While we are re-engineering GM brakes, has anyone tried this on surfaces other than dry asphault?![]()
