Well money is a little tight after buying the truck, and I still have some other parts to purchase to get the cab in order. If I could get away with swapping some parts into this one, I think I'd like to give it a try and cross my fingers.
Also, this motor is incredibly clean inside. All the lifters seem to be in great shape, as well as the cam, and there is NO crud or sludge ANYWHERE. I couldn't even believe it. It looked brand new under the valve covers and in the pan. I'd hate to go buy another used motor in unknown condition, you know?
So do you think the piston is trashed? It's a shame they can't be loaded from underneath, but at least I only have to pull one head off. I was thinking of replacing the #7 rod bearing for good measure, just in case it's had some unusual stresses on it. The twist in the #8 rod has been putting a bit of side-load on the pair of rod bearings.
If I do need a piston, rod, two rod bearings, head gasket, head bolts, oil-pump o-ring, etc; where is a good place to get those things? I know some of it can be had at the parts store, but I don't know about the rest. Is there a brand or style that I should stay away from?
