Sold (5) Hard to find ProComp Series 75 Trilogy Race Bead lock Wheels - Machined (17x9 / 6x5.5 / -30mm)
Calvo
El Blazer
Tucson, AZ
Click here for Video
This model is sold out almost everywhere - including Amazon! Offering up 5 lightly used copies for $2000!!
Paraphrased version of the manufacturer's description:
The next-generation Pro Comp Bead lock Wheel is here to take on the most extreme terrain imaginable. The new eight-spoke design yields a classic hardcore look. Way more than just a pretty face, it's engineered to be 27% stronger than the previous version and uses a completely redesigned bead ring which is double the thickness of the original and forged from 6061 aircraft-grade aluminum. Fully countersunk Grade 8 bolts stay protected from rocks, impacts and abuse while NORDLOCK washers ensure that the ring hardware stays properly torqued. The new ring also uses a specialized 45-degree diamond knurl pattern while the bead area of the wheel features Pro-Comp's patented Infini-Grip figure eight pattern. Together they form a super team of grip that keeps the bead locked securely in place regardless of air pressure or impacts.
  • Pro Comp Alloy Wheels | Part Number: PXA1175-798337
  • Bolt Pattern: 6 on 5.5
  • Center Bore: 108
  • Offset: -30
  • Series - Finish: 75 Series Trilogy Race Bead lock Super Machined
  • Fitment: Universal Fit
  • Style: Bead lock
  • Series: 75 Series
  • Brand: Pro Comp Alloy Wheels
  • Backspacing: 3.75
  • Construction: Aluminum
  • Finish: Machined
  • Wheel Width: 9 Inches
  • Wheel Diameter: 17 Inches
1 ProComp Series 75 17x9 6x5.5 3.75 SPR Machined .jpg 20210617_220201 Rebeccas.jpg 20210408_185107.jpg 20210322_145907.jpg
