ok, now im confused
Same as 52s. The extra 4"s is behind the center (or offcenter in this case) pin. 52s have the centering pin in the middle at 26"/26". 56s are at 26"/30" for clarification.
muddermilitia and i discussed this in his build thread right here, @ post 277 he said 56'' could only run turned 1 direction, so i'm lost now...here goes nuttin..
http://coloradok5.com/forums/showthread.php?t=195380&page=3
i had planned on b52 /56's and zero rate moving axel
back 1 1/2'', to get me back close to stock
wb .... @1'' forward....now i see all this....so, i can just swap sides w/ front hanger and it would put hanger in front of rad support mount and 56'' will bolt up, and longer shackle will help take full advantage of springs lenght.....but not good for street????
we also talked about crossover and hi steer here
http://coloradok5.com/forums/showthread.php?t=223807
so i guess i will just out right ask if what i'm thinking will work...(sorry for hijack, but i think its really same thing you are asking)
i was planning b52/ or swap sides with front mount(??) and 6'' 56'' spring, zero rate used to pull axle back and ?6''? shackels..up front....6'' 56'' springs in back w/shackle flip and ??(what ever it take to level k5)?? lenght shackles in the rear, to get 9-10'' of lift, and still be streetable? oh yea wanted to run the ord or some type of histeer(i've run into stuff in the mud and bent crossover b4...so am i thinking straight or should i just get a 10-12'' stock lift and btw..either way i want histeer and will be running as big a tire as i can afford since i got me a d60f
,..maybe even 53'' michelinsw/3 more'' of body lift,...i no you guys dont like the body lifts, but i see no harm in them running in the mud and light i mean light trails or flexing?
