yup 100% sure it's a 6l80e
HMMMM..... will the 4l80e bolt up to a 241 t case?
Wow... must be alot of work.
Just to be sure that's if you supply the harness?
Check with Speartech, he worked at GM for years and now he does aftermarket harness and PCM stuff. He's very reasonable as far as price and does a flat out awesome job on reworking a harness. I sent him a stock denali harness with a million wires and he reduced it down to only what I needed, changed the tranny wiring, and reduced a huge fuse block down to 3 fuses and 1 relay.
I'm sure the 4l80e is longer than the 700R4. I think 4WOR did an article on a 4l80e swap a while back....
(everyone in the shop was running out/ducking for cover)
