Hello all I have an 82 k5 with the 6.2/th400/208, I’m not sure the gear ratio, came on decent 33s, I want remove the 6.2. I’m not sure if I want to do 6.0/4l80 or I was recently thinking a 4bt swap. I plan on using the truck for a Daily driver and towing a 3500lb boat. From I can tell they will cost around the same. But the 4bt would have a cool factor and few less things would need to be messed with considering the truck is already a diesel.
That being said, from what I can tell I can run the 400 behind the 4bt, or I could still go with the 4l80, but would need a different TC.
What do you guys think
FWIW I am very familiar with LS swaps, I’ve done quiet a few, and I’m pretty familiar with diesel applications, but not so familiar with diesel swaps
Thank you in advance
