I dunno on the Tach I'm no help there
Just run a manual push button for GP's, it's the easiest way to not burn them out and you always get to decide how long to glow for. Ford solenoid for the draw end of things, trigger wire to push button.
Tach needs either the alt version, or stick on magnets on the damper, and I believe there is also another version that clips to an injector line and can sense the pulses which generates a tach signal. None are easy or spectacularly cheap.
Might want to check a 60 series truck out, as those did have tachs for diesels that were good size. No idea how they got signal though.
Stock exhaust was 2.25" true dual. 2.5" duals with 40 or 50 series flowmasters would give it more of a big block sound to it,n point is at the manifold outlet which is 2.25". Alledgedly they can be hogged out to near 2.5".
For wiring you'll want to wire in the HPCA too, and utilize the temp sensor. When under 120F it bumps housing pressure in the IP, which bumps timing and makes a very noticeable difference in cold starting. Much smoother and less start-up smoke.
Rene
except i would want a fullsize extended cab. alittle something to haul camping gear and some kayaks. stomis your making mad, you got the wheels turning and now got me thinking about a 96-99 with a 6.2.except i would want a fullsize extended cab. alittle something to haul camping gear and some kayaks.
how much can a 6.2 tow respectably? if i wanted to tow my k5 around with that push it to much?
Have you already picked up your s10? I know you were wanting a CC s10 and I found one down here for a great price lol
Russell is currently running a NV3500 in his K5 if I'm not mistaken. Ask him though, I did and got lost about 15 words into it. He can tell you all about it.
I honestly don't know how inspection is going to work for diesels. Knowing jersey it'll either be really ****ed up or nothing at all.
For your app I wouldn't think twice about buying just an engine. These engines require very little wiring. What the other guys have brought up is good info. Glow plugs just do a manual setup, very easy to do. Fuel system is easy even with an electric life pump. Exhaust is very simple too, what yellowK20 said will work well and sound good too.
For a tach I'm using the Autometer that runs off the alternator. Works pretty good, don't remember what I paid though. I did buy it 7 years ago.
As for parts like timing gears and such you have
www.kennedydiesel.com
www.heathdiesel.com
www.dieselservices.com
The 6.2 came with a mechanical fuel pump (lift pump) mounted on the block.
Sounds like you alread made up your mind on the 6.2 but I will share my experiences anyway. I bought my Blazer in '94 with 49k and it was stock minus 32" tires. 700r4 and 3.73 gears. Point being, it was a good representative of how these ran from the factory since it was low mileage and well-maintained, and had decent gears. I've seen a lot of people base their opinions on these trucks after driving a 150k unmaintained and beaten up old work truck with stupid high gears.
I daily drove mine for years and it did fine. Previously I had an '83 S-blazer with a carb'd 2.8 and the 6.2 felt a LOT faster than that truck. My dad had a new TBI 305 pickup at the time and they felt similar, and I also spent a lot of time driving late 70s to mid 80s farm and work pickups and even big block trucks of this era would be considered dogs by todays standards. In any case, I would not hesitate to daily drive a 6.2 truck to this day even after driving a 300 HP truck for the last 8 years.
