On second thought, it's a piece of junk. I'll give you $500 for it.
Thanks guys, the thing that scares me is the previous owner wasn't a very good mechanic based on the Mickey Mouse fixes I have found, I have never seen the temp go past 210 it always comes back down but that's because I put a new hd fan clutch on when I replaced the waterpump.
It's not the fact that I have to baby it actually it's more the issues with being stuck somewhere with a pretty substantial load. If this was a cummins or it's a lot less likely to suffer a failure when well cared for vs a 6.2 that's well cared for, one is just heavier built for the intended purpose.
The other thing is this truck felt out braked and just too light around these hills and in the wind to take this sort of load, figure the only thing I tow is 4-6klb trucks with trailers 2-3k empty. My burb has more weight overall, my 92 is longer and close to the same weight. But feels the same.
I just think it's wiser for me to find a bigger truck to do what I want and feel comfortable about it.
One thing I want to point out is if I suffer that kind of catastrophic failure towing my own vehicle it's one thing but for it to happen to me while towing a customer vehicle is another. Not saying a cummins dodge or swapped Chevy won't do that it's just a lot less likely than the setup I am using now.
@secutright has a 93 dodge cummins, my mom has an 2004 also and it's been stellar. I've been around them a decent amount with other people I know and they all swear by them. Second place is a powerstroke and last being duramax and most of that's related to cost because those trucks are newer.
My burb is awesome at making other cars feel way better than they actually are.
...after working on mine I would say pulling the engine out and dropping a "good" one back in would be a hell of a lot faster and easier than trying to repair one in the chassis..
After the experience I just had with my 6.2,I'm ready to answer the question "what are they good for" with the answer "a good boat anchor"..
No I'm not a "hater",but my enthusiasm for these engines has diminished greatly over the years...they seem to have a reputation as being the "second worst GM diesel" ,with the Olds 350 taking the #1 spot..
Yes,I have owned this truck 13 years,had practically no issues with the engine other than glow plugs,and frustrations with a rotted oil pan,I admit I didn't maintain it exactly wonderful,and it wasn't till a few weeks ago it finally left me stranded when the fuel filter finally clogged,which had been on it since I got the truck in '03,but looked fresh then,and I only drove it 7500 miles since..for the abuse I received I cant complain about it..
My biggest dislike of the 6.2's are they seem to hate me when it comes time to work on one..many things are a sucky design on them..
Things that appear easy to reach aren't,and a lot of delicate expensive parts like injector lines are easily damaged or destroyed, and many parts I've attempted to remove like glow plugs are "stuck",swelled up,and I never liked the vacuum pump idea to run the transmission modulator and other accessories..
I've put three starters in this truck so far..the Delco direct drive one is great for crushing your fingers,its a battle holding that 40 lb ingot up while you struggle to get a bolt started..(and if your lucky both bolts holes are still there,not stripped,or a chunk of the block broken off there!)..
I have an '87 parts engine that snapped a crank--it ran perfectly till the big "whack"--it was in a C30 ramp truck though,and was likely tired and abused...good thing I snagged it,because the exhaust manifolds alone for a 6.2 ,if you can find any new ones,are close to 400 bucks..
It took me 4 days of 5 hours each to remove all 8 exhaust manifold bolts on the drivers side of my 6.2,which required much torching,had to cut every bolt head off (they were like rivet heads due to rust)..then cut grooves in each bolt boss,then the manifold still refused to budge even prying with a 4 foot bar (and I bent it!)--it felt like it had welded itself to the head...finally I resorted to using a long hunk of 1" round stock and a 5 lb hammer to get it off the remains on the bolts..
Whoever designed the manifolds to mount to the heads at a 45 degree angle,and have all the bolts point right at the frame rail deserves to be shot--cant use anything but a box end wrench on them,except the two rear most bolts--the bolts in the center are so long the new ones hit the frame rail,and had to be coaxed in with hammer blows..
(I think it might have been easier to just pull both heads off,and plop the ones off my parts engine with the manifolds still bolted on,or pull the engine out,that do a manifold "in the truck")..the bolts on the parts engine came right out,and could have been re-used,but I opted to buy new bolts for 12 bucks..
I had to braze 7/16" nuts to the remains of each torched off bolt,and could only use a open end wrench to try getting the remains out without breaking them off in the head..the two rear most bolts sucked the worst,and I was amazed all 8 bolts actually came out..but not without a great deal of effort and discomfort..It took about one hour per bolt,with much heating and cooling cycles before they came free..
Holding a 20 lb ingot manifold in place for 30 minutes after it taking that long just to thread it in there like a needle and get a bolt started,thanks to the manifold being "angled" I think took 10 years off my life--every muscle I have aches so badly now I'll be sore for a month at least..
I've sworn off any more diesels..
I dont "need" one,I only bought the pickup because it was very cheap and didn't run when I got it,and at first owning a diesel was "fun"--- why I went and bought an '85 Burb with a 6.2 in '09 I dont know,temporary insanity maybe--?..or I figured if nothing else it'd be a good parts truck for the pickup..but now I'm soured on them enough to not even want it now..
I would much rather have a good old 350 or 454 ,or any other gas small or big block...if my 6.2 ever needs a water pump ,or injector pump replacement or repair,I'm just going to either scrap the truck or pull the engine and swap in a gas one..I've always hated any engine with the water pump setup they have,with a plate behind them that can let coolant into the crankcase..(Caddys,Buicks,Fords,Etc)--I like the gas engines water pumps and straight sixes--4 bolts and a 1/2 hour and your back on the road..
I would hate to be a soldier in Iraq or Afganistan that had to depend on a 6.2 to get me out of a bad spot..
I think the main reason the military chose them is the fact GM was willing to make millions of them and sell them cheap,and the military considered them disposeable..
I have read the average life span on a 6.2 in combat conditions was 1000 miles.....after working on mine I would say pulling the engine out and dropping a "good" one back in would be a hell of a lot faster and easier than trying to repair one in the chassis..
Like I said,I'm not a hater,but I'd like my 6.2's a lot more if they had been designed differently and easier to work on...I think they make a better engine for farm or industrial machines than a road driven vehicle...I sincerely doubt I'll ever buy another diesel powered vehicle,excepting perhaps a VW or old Mercedes...I do miss my VW Jetta diesel,but that also sucked to work on..also all diesels are "interference engines".so if you lose a timing belt or chain,the rest of the engine gets destroyed...no thanks..![]()
..I think you qualify as a diesel hater by this point (based on your many rants). But that engine has taken heaps of abuse and simply refuses to quit. Can't call it an engine failure if a decades-old plugged fuel filter cut off the fuel supply. That's neglect, not the truck's fault.
Yes, the manifolds are a pain, no argument there.
