Just measured for a new Aluminum radiator with fans because I’m not sure I like the fit of the 06 Silverado SS one that I have. After measuring it up, I pulled out the radiator from a ‘70 big block El Camino & it fits perfectly after relocating the bottom mounts 1/2” toward the engine.
Now I’m thinking I should just go with that.
Does anyone have a reason not to use it with the 6.0 LQ9? or just spend the $600 plus for the cooler Aluminum one?
if you’re looking for a cheaper aluminum option with fans you might want to checkout @SpeedlabDan first gen thread. I’m also using the same brand (different model) on my K10 with a BBC. I paid $265 to my door for the radiator & fan combo.
First Gen, all hardware no software
If the thermostat isn't open, there shouldn't be water flow in the upper hose to build pressure in that hose over what the system pressure is. Would you explain your theory a bit more? If the cap held too much pressure, then the weakest point becomes a failure potential. And an old radiator...
