Got started on cleaning up the barn, trying to find space to put all the big parts that are starting to pile up. Decided the best place for everything was on the truck.
Bolted down the front half with the correct body mounts/lift, took some measurements then broke out the Sawzall.
Did some touch up painting on the frame and gas tank where it got scratched when the body fell off.
Few shots of the bottom of the old one. Could it be fixed...yes, but that it way more work than I want to do.
Set the new bed on along with the step up panel. The two are bolted together tight, but loosely bolted to the frame. I want to get it squared up real well before I tighten it all the way. Had to add some shims to the second to last mount. There is actually a post over at 67-72 from someone else who had to add some in the same spot so I'm not too worried about it.
Finished pulling the packing off the cab floor and set that up on the bed. Being it's for a truck cab, I'll need to trim a few inches off the backside for it to fit correctly as well as open up the transmission tunnel.
Before pulling the bed off, I removed the tailgate/its hardware/lights/wiring/filler neck. Wheel tubs still need to be pull, same with the door latches and shims. Will also save the stands for the inner trim panels. Don't plan on getting rid of it untill I've got all the new parts on/fitted.
